Thanks a lot. Exactly what I was looking for. I'll measure out the crank and bearings. And reuse what I can. Everything looks alright. So may end up reusing some things. As for the transmission that's apart and going to be a bear.
Anyone know off the top of their head what 1st undersized measurement is? Also difference between 1st undersized and 2nd undersized is?
Most people are afraid of transmissions until they get into them.
Are you making the assumption that you'll need under size bearings or, do you know you have a problem. Guzzi cranks are tough. Last year a tore down a rough 850 motor, the bearings were shot and the crank looked really bad. I ordered all new first under bearings and sent it off to the machine shop. He called a few days later and said the crank cleaned up in the acid bath and polished up just fine, standard bearings fit perfect. Make sure to clean the sludge trap.
It looks like it original equipment and matches the one on MG cycles improved oil pump but not from a billet block. Strange I guess.So should there be 2 cages of roller bearings in there to even the load out?
Should I put the 1K cc in? Or leave it as is?
Sounds about right. I have had carbs and the intakes vapor blasted as well. The belt cover would not have been chromed originally but you do see them and the valve covers sometimes chromed. I really like vapor blasting.
Anyone know if MG Cycles Seal Kit has all updated viton seals? Some of them look like they are.
